1 - 19 of 19 Posts
ran into righteousriley05 this evening from here and raced him..Just wanted to say good rac. It was closer than i expected especially you being stock.
^^^^^hows the stage 1 kit do compared to stock
like night and day, i have an intake also, i want to get extrude my own header tell me how you did yours.
somebody was selling a stock manifold and i bought it.
i used a drimmel tool for the ports, then i bought a 1 inch bottle hone for the rest
made it amooth as a babys bottom
not much to take out at all
i ordered a gmpp gasket and did a small amount of port matching
and guess what i have the stage 1 on order should be here tomorrow
WEEEEEEEEE!!!!!!!!!! stage 1 jon! FTW!
yea i know its awesome
Now, stage 1 comes with the 42.5#ers right?
yes it does w/ a tune and directions
Discussion Starter #9
thats what I thought... dang, he could get a 2.9 like me if he had a stage 2 hub... he needs to find if someone will sell him a stage 2 hub.
or i could buy it seperately
like intense or some other places ive been at
it will be cheaper
and how do u know its the same as stage 2 super
Discussion Starter #12
jon he is def right, except the tune is slightly different.
stage 2 only comes with a smaller belt, 77.9mm pulley, and hub. And you already have the injectors with stg 1
so the injector portion of the tune is the same but there is no tune for the pulleys, considering there is no pulleys in the stage 1
exactly, so if you put the stage 2 pulley on with stage 1 tune, you will be running too lean. Thus, if you could find a deal on the stage 2 hub/pulley (for cheap) you would have a stage 2 setup, with supporting tune! But, I would go with a custom tune, which I am fixing to do hopefully...
if i put a pulley system on it then the afr's should change for too llean
I did pretty much the same thing. Worked really nice, i can even hear a difference in the exhaust note. Idle sounds much better now. I would reccommend it to anyone that doesn't mind doing this kind of stuff themselves. I still have an extra stock manifold if someone wants to buy it. Or I could port it.
1 - 19 of 19 Posts
