i have a 06 ss sedan w the 2.4 automatic and i want to swap it out with the 2.0 supercharged manual. i have the harness and computer but the question i have is will the eng harness plug into the body harness and be correct or will i need to swap it out also. or can i just nstall the super charger and trans on my 2.4? :eek::confused:
wow..... swaping out the motor and trans for a 2.0 is going to be a lot harder than you think it will be, none of the wiring is the same not to mention other problems you will run into
http://www.crateenginedepot.com/store/Ecotec-22L-CavalierSunfire-Supercharger-Kit-17800003-P1377C502.aspx
with some modification this kit fits cobalts, this would probably be the easiest thing for you to do, it will work with the automatic transmission you wont be able to use the gm flash but a good hp tune will work
another easy one would be
http://www.vulcanturbo.com/GMTurboKits.html
scroll down to the cobalt kits he has a few different ones and the only thing you would need after installing the kit is a good hp tune
