1 - 20 of 28 Posts
I noticed today that my SC was making more noise than I remember it making previously. Was just curious if any of your SCs are making rattling noises at idle.
TIA!
Oldbenwa
Edit: Oh, only 1200 miles on it so far, mostly highway.
Premium Member
mine makes all kinds of noise while driving. It may be the tranny. its hard to isolate are you sure its the supercharger?
Discussion Starter · #3 ·
I put my ear like 2 inches above it and moved my head all over the engine compartment, noise was definitely loudest directly over the SC.
Oldbenwa
yeah i hear that too while idling, and it definatly seems to be from the supercharger, i wish i would have paid attention when i first got the car to see if it made some noises then.
Just take it to the dealer & lets kill the "I wonder factor" & lets us know... :D
Discussion Starter · #7 ·
I'll mention it to them when I have my passenger door panel replaced, see what they think. I'll let you know.
Oldbenwa
oldbenwa said:
I would do this how?
Oldbenwa
Dont touch it... It would be a reason to have GM say...VOID! :mad:
I just noticed the same thing like 5 minutes ago.... It sounds like rocks are being grinded and tossed around.
Although I did just pull up to a redlight and forgot to push the clutch in...
Discussion Starter · #13 ·
That perfectly describes the noise mine makes. The dealer still hasn't gotten my door panel in so I haven't taken my car in yet. Let us know if you do.
Thanks!
Oldbenwa
We like to refer to it as "The Can of Marbles Noise"...
Mine has done it since day one, a few other guys have as well. Someone got their blower replaced based in the noise, but it seems like 90% of the cars have it. Much worse in the winter when you first start up too....
Banned
This is a common problem on higher mileage GTP's. Theres a plastic composite coupler inside the snouth that couples the blower drive thats connected to the pulley to the gears that turn the rotors. Maybe Eaton installed some out of spec couplers in your blowers. Worth looking into.
The coupler noise is considered "normal" at idle. It will generally get worse as mileage accumulates. Some dealers are replacing the SC for it , but there's a TSB coming to tell them NOT to. (as it just returns after a couple thousand miles)
If it really bothers you- you can certainly relace the stock couple with an "improved" non-oe unit such as the one from ZZ
http://www.zzperformance.com/products1.php?id=155
HTH
WOT
Do they already have the TSB yet? My noise has gotten louder and people have mentioned that my cobalt sounds like a mac truck :(
No, but I was told it's supposed to be released soon. If it's real bad, they might just change the entire sc, but the reality is- it's not really harmful.
WOT
1 - 20 of 28 Posts
