This might be my first trip to the dealer. Basically what happens is when shifting into reverse, it does not happen everytime but enough to make me never want to put it in reverse except for when the car is off, the gears grind. Yes, grind, that god awful sound of your gears geting destroyed. No matter how hard I push the clutch in or pull up on the reverse lock-out ring on the shifter, it grinds, even just after starting the engine before the car even moves. Anyone else have a similar problem? Or had the problem and found the reason? I guess it could be as easy as letting the car sit a few seconds after putting the clutch in, but either way I have never had a car do this to me before.
