Hey is there a place on the web that will display the TSB's for our car and that explains the enitre TSB. I have gone to edmunds.com and it shows the TSB but doens't go in to detail. THanks for the help guys.
I can get you more details, what do you need??
I need the complete TSB on the Fuel gauge problem. It moves off of full to quickly. The bulletin # is 060604012 and is dated March 2006. I would appreciate the help. I know when I owned a camaro the complete TSB's were online. Why cant we have this for our cars.
Document ID# 1794581
Subject: Erratic Fuel Gage Readings (Does Not Go to Full or Moves Off Full Too Quickly) (Replace Fuel Level Sensor) #06-06-04-012 - (03/22/2006)
Models: 2006 Chevrolet Cobalt
2006 Pontiac Pursuit (Canada Only)
Built Prior to VIN Breakpoints 67735784 (Chevrolet) and 67735794 (Pontiac)
Condition
Some customers may comment on erratic fuel gage readings. A typical comment might be that the gage does not go to full or moves off full too quickly.
Cause
This condition may be caused by an improperly calibrated fuel level sensor.
Correction
Do This
Don't Do This
Replace the fuel level sensor
Do not replace the fuel pump module
Replace the fuel level sensor. Refer to the Fuel Level Sensor Replacement procedure in the service information.
Parts Information
Part Number
Description
88967308
Sensor Kit, Fuel Level
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
L1197
Sensor, Fuel Level (Tank Unit) -- Replace
Use Published Labor Operation Time
Add:
Diagnosis Time
0.0-0.3 hr
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
There ya go, sorry about the delay in getting back to you, i had to install my new downpipe and then i went home, didnt get a chance to check until i got back to work today.
Appreciate it. This applies to the Cobalts correct? I just saw the Pursuit on it.
Yes, it is for the Cobalts.
