1 - 1 of 1 Posts
Harrop tvs basic requirements
all you need to get you on the road
bare min:
60lb injectors
tune
stage 2 belt
Should be basics be aware 3" is always better
Good 280hp to 310hp
intake/3" intake
header down pipe
exhaust
heat exchanger
spark plugs
over 310hp best bet to get the numbers you want
in addition to the above
80# injectors
meth
dual pass
option b
return fuel line
catless down pipe
fly wheel plus clutch
(spec stage 3+, ACT HDSS, Centerforce, Exedy )
3 inch exhaust
stage axles
and if you really want over 400hp
ported head
cam kit
fully built b***om end
120#
OVER 500Hp
TWIN CHARGED from ZZP
3.14-18psi
3.0-20psi
2.9-22psi
2.8-23psi
2.7-25psi
please add if forgot anything
1 - 1 of 1 Posts
