1 - 20 of 22 Posts
Besides the charge air pipe that pops loose and the paint that rubs off on the bottom of the doors, what other common problems should I look for before buying a new 09 SS/TC?
rear brakes dragging and putting a groove in the rotors. hasn't happened to me yet but it has to a couple of people on another site.
intake camshaft sensor leaks oil. no fix yet but gm is aware of it. the dealership just replaces it with another that will leak again eventually.
The rear brake issue sounds like the emergency brake is binding. It's common on 05-up Mustangs as well and usually it is because the e-brake line is rusted/frozen.
its not in the e-brake housing its on the rotor. these are 4 wheel disc brakes. the emergency brake is a drum set up inside of the rotor.
Ok - I wasn't sure about that, the S197 Mustang e-brake is the service brake (rear pistons are screw-in), my Crown Vic has the drum set-up for the e-brake (service brakes are all discs).
Are the rear SS brake calipers on sliders? Is it a lubrication issue? Or perhaps it is a friction material problem? My stock factory Crown vic pads chewed the sh*t out of my stock factory rotors.
its not a lube issue i don't think. all the cars having the problem are 10,000 miles and under. i only have 4,000 and i here the rubbing but i don't have a groove yet. there is a tsb for the noise but not for the groove.
yah i herd that too but it hasn't happened to me
yes it does. Already in the dealer twice for that crap^^^
I'll be honest, i shift it pretty hard and really fast. But its a complete shift, no grinding or anything. The clutch HAS slipped a few times though
Also you might wanna check the CD player, i have an 08 and i had issues with mine recently and took it in and got a new one but i guess if you are planning on taking out the stock player than you have no worries... Just thought i would let ya know :) Happy hunting
Discussion Starter #15
I am going to keep the stock audio unit. They all come with the USB port, apparently it was a change for 2009.5 SS/TC's.
Well i have an 08 and the CD player messed up on it but they will replace it under warranty if it does, anyways, good luck
'09 tc
Was pulling out of the car wash today and the display goes crazy. "service esc" I have had it for less than 2 months and its already going to the service department!
Yeah, esc shut down, light came on, ding ding. Had a loud shut down noise to it. Thought i blew a tire. Oh well its going in for service tomorrow. I'll find out then.
Oh when i first got my car, i went to go and wash it and the next thing i knew the engine light came on and then i drove it to the gas station and it died there. It started again but i took it in and they had to get me a new ecu...
1 - 20 of 22 Posts
